Max length for part name input field
pyalavarthi
Hi all,
We customized to increase the part name column to 240 characters.
However in the UI for create and rename part wizards, the input element for
part name is limited to 150 characters.
It looks like the html is getting generated from server side class. I was
wondering if anyone have an idea of modifying. We are using PDMLink 9.1
M030.
[image: CreatePartWizard.png]
Prathap <">http://goo.gl/LuT5>
Did you check codebase/config/logicrepository/xml/AllClients.xml ?
Sent from my Verizon Wireless BlackBerry
Did you try section "customizing column length" in Customizers guide .
Dhananjay Sandbhor
