Hi everyone,
While watching a PTC webinar I saw that in the structure visualization panel in Windchill there are measurement commands (see image 1).
I checked my system (version 12.1.2.5) and I don't see them(see image 2). How can I add them?
Is there a property or preference to set?
ty,
Matteo.
How old is that webinar?
The note says that measurement is only for Creo View, not the webgl plugin.
I think the webinar is from 2021. So unfortunately, from what I understand, the feature either doesn't exist or has been removed. Thank you, Matteo.
@avillanueva is spot on, Windchill 12.0 and later only supports the webgl plugin which does not have these features. the non-webgl plugin only worked in Internet Explorer. i was happy to retire it 😁
Hi @ScottMorris
I would just add that diameter measurement didn't work properly in the web creo view plugin
PetrH
