Member Not Found error while saving inventor assembly having derived substitute model to windchill.
BikrantS
8-Gravel
We are unable to save inventor assembly having derived substitute model to windchill.
While trying to save the inventor assembly to windchill it shows "Member Not Found" error in the windchill workgroup manager. The issue is reproducible in all inventor assemblies having derived substitute models.
How to fix this issue?
Hi @BikrantS,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
hasretsimsek
6-Contributor
(To:BikrantS)
Have you found a solution to the issue?
I'm experiencing the same problem right now.
