Method server doesn't start. Error : [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece ]
alonkar-2
Hi All,
Suddenly we start experiencing issue with our production as well as Test server.
We are using Corporate Ldap for Server for user login.
User were not able to login to server so we took down the server and now it is not coming up with below error in Method Server:
Error [LDAP: error code 49 - 80090308: LdapErr: DSID-0C090334, comment: AcceptSecurityContext error, data 525, vece ]
Any help is appreciated.
~Amit
Is your Windchill able to ping the AD server. If so, can you telnet to the
AD server?
telnet {AD_SERVER_HOSTNAME} {LDAP PORT}
Example: telnet windchill.domain.com 389
It appears Windchill can't communicate with the AD server. This can be
because the connection is broken or the Username/Password is not valid.
Hi Ryan,
Able to ping to AD server as well as telnet is also working with port 3268 which we are using for corporate LDAP
~Amit
Amit,
Go into wt.properties and update the following property to look like
this.
wt.federation.org.directoryServices=$(wt.federation.org.defaultAdapter),$(wt.federation.org.enterpriseAdapter)
Try to start Windchill. Does it start ok?
