[proecad] - Export CAD from Windchill
  • September 24, 2014
  • 0 replies
  • 415 views
Wait just a second, I think your making this more complicated than it needs to be.
Create a startup script for Creo that selects a different location for the cache.
Have the user register the server.
Open the files in Creo, and then Save a backup to a folder.
Exit Creo
Then open Creo the way you normally do and browse to the folder. \
Your startup script would need a line something like this:
set PTC_WF_ROOT=%USERPROFILE%\pro\creo_2_home\cache\no_pdm_cache\PTC\ProENGINEER
Both startup scripts would need this line in them:
tskill creoagent
This prevents the creoagent from informing Creo of the last registered server.
Look at these two presentation on connecting to multiple servers
Creo<">http://communities.ptc.com/servlet/JiveServlet/download/3205-5-45122/CUST134_Creo_Creo_Admin_101_Haigh.pdf> Admin 101<">http://communities.ptc.com/servlet/JiveServlet/download/3205-5-45122/CUST134_Creo_Creo_Admin_101_Haigh.pdf>
Creo<">http://communities.ptc.com/servlet/JiveServlet/download/3883-21-54294/CUST110_Creo_Admin_101_Haigh.pdf> Admin 102<">http://communities.ptc.com/servlet/JiveServlet/download/3883-21-54294/CUST110_Creo_Admin_101_Haigh.pdf>
David Haigh
