MethodServer fails to start with error "Failure to start manager wt.index.StandardIndexPolicyManager"
Hi guys,
When I try to start Windchill services, I get this error in MethodServer logs:
ERROR [main] wt.method.server.startup.services - Failure to start manager wt.index.StandardIndexPolicyManager
wt.services.ManagerException: Couldn't initialize Index manager.
Nested exception is: wt.util.WTException: java.lang.NullPointerException
Nested exception is: java.lang.NullPointerException
At the same time, I get this error in BackgroundMethodServer logs:
Nested exception is: wt.pom.ObjectLockedException: The Repository - object is already locked in the database.
Nested exception is: java.sql.SQLException: ORA-00054: resource busy and acquire with NOWAIT specified or timeout expired
I opened a case to tech support but they don't seem to be able to help me. So, I come to you today and I REALLY hope that you can help me.
For information, we made a rehost from another Windchill server (database + LDAP people node) and we cannot start Windchill since this time.
Thank you all.
Florent
