Yes, we have experienced this issue in WC 7.0 and 8.0. ProjectLink routings
use Project context team. Workflows initiated in PDM use process team. The
rationale behind this design was to maintain / carry the Project Level
security policies defined for projects to Workflows. However this feature
has changed in 9.0 and beyond.
We solved this problem by adding the code within the workflow to create an
instance of the Project Context Team, and assign this team as the process
team for the workflow (Roles must match). Solution would work only under the
assumption that Project team (roles and members) assigned to the process do
not differ between the Project and Process instance throughout the period of
process execution.
You might need to reevaluate the above solution when you upgrade to WC 9.0 +
Hema Jatla | Datafrond LLC -
hjatla@datafrond.com | Fax: +1 480.247.5908
