ModelCHECK problems in WC9.1
Dmi3U
Hi All,
We just switched to WC 9.1 m040. Since then my modelcheck stopped working - I had to disable it. We had configured gatekeeper back in WC8.0 and it had been working fine till now. When we switched to 9.1 we started getting checkin failed with "ModelCHECK failed on model(s) in the context " and "Incorrect set of config files used on ModelCHECK in the context ".
I have a call opened with PTC- their respond is to make sure the syntax is correct and no additional characters in the definition of ModelCHECK Configuration pref in WC. That has been checked...
Anybody else seen this? What is the solution?
Thank you in advance,
Dmitry
Dmi3U
(To:Dmi3U)
Hi All!
I got a respond from one over user who got into the same problem. I was checking for extra parameters because PTC told me to do so. And I was relying on PTC's documentation(big mistake).
In the documentation it says the configuration should be as follows:
Default:check/default_checks.mch,start/default_start.mcs,constant/inch.mcn
Note: there are no spaces after coma in the documentation and this is why it did not work. I added spaces after comas and it works.
Dmitry
Many many thanks!
I suffered for several days because of these spaces!
