We have situations in which all or at least many of the WTDocs (Describe links exist from WTDoc, not RefDoc) need to be modified at the same time. Each currently needs to be checked out, then edited then checked in separately. Is there a way to check out / in en masse? Ideally this would work similarly to the New Multiple documents. Even better - we would like there to be an option to check out selected associated docs when cheching out the WTPart (similar to Revising this set of objects) - ideas?
thanks in advance
