Modify the OIR for Lifecycle
AP_10483126
Version: Windchill 13.0
Use Case: How can we modify the OIR to add a condition that if it is a design view it should follow lifecycle XYZ and if the view is A or B Or C it should follow the lifecycle EFG?
Description:
7 REPLIES 7
Fadel
23-Emerald I
(To:AP_10483126)
for view its not gonna work in the newest releases , you can do it based on other attributes
https://www.ptc.com/en/support/article/CS396081
Fede
AP_10483126
(To:Fadel)
But i am looking for the view based one. Can the view attribute used in this solution ?
Fadel
23-Emerald I
(To:AP_10483126)
FOR VIEW ITS NOT FEASIBLEhttps://www.ptc.com/en/support/article/CS316768
Fede
AP_10483126
(To:Fadel)
can we create an IBA and then store the view.id into that IBA at the time of creation and then put the condition on that IBA ? does this work ?
Fadel
23-Emerald I
(To:AP_10483126)
technically yes , the IBA will requires a custom data utility to get value from view
Fede
AP_10483126
(To:Fadel)
using the following tags i was able to achieve in OIR
<AttrValue id="lifeCycle.id" algorithm="com.ptc.core.foundation.lifecycle.server.impl.LifeCycleTemplateAttributeAlgorithm">
<Value algorithm="com.ptc.windchill.mpml.algorithm.ViewToLifeCycleAlgorithm">
Hello @AP_10483126
It looks like you have a response from a community expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
