Moving from product to library
ErikClacey
I have parts and assemblies that are in the Product structure in Windchill 10.0 that are actually supposed to be reused by everyone, so I would like to move them to the Library structure instead. The products are already used in other assemblies.
So how do I move them to the Library? When I try using Move on the part, I can only see the Product folders, not the Library folders so I'm stuck.
GregOlson
(To:ErikClacey)
If you are trying to more objects from a Product to a Library and you cannot see the library it's a poly admin issue. You will need to contact your Windchill Admin for proper move permissions.
There are three Move permissions - not named in such a way that anyone would guess what they are:
Change Domain - leave where it is* applied where it currently is
Change Context - leave where it is* applied where it currently is
Create by Move - go somewhere new appplied where it needs to go
* relates to how far away the new place is; see Help
Attempt to move as Admin. If ok, then defintely it's a permissions issue.
LoriSood
22-Sapphire III
(To:MikeLockwood)
For your reference the required permissions are documented in the Windchill Help Center (WHC) in the "Permissions Required for Moving Objects" topic (http://www.ptc.com/cs/help/windchill_hc/wc100_hc/index.jspx?id=AccessControlChp_ReqPermissionMoveObj&action=show)
As well as in this article:
http://www.ptc.com/appserver/cs/view/solution.jsp?n=CS26516
As an FYI, in many cases, the permissions required to perform certain actions can be found in the WHC for 10.x
Thank you for your assistance
amazing man
