Hi all,
I need an urgent help. In Policy Administrator page while trying to fix something, I made a mistake and the WTObject for the Administrators group got a Deny Access instead of Full Control.
Hence because of this Im unable to perform any activity on my system.
Is there any way I can revert back and update the policy to Full Control on the Administrators group?
Please let me know.
Hi Nikita, if you are still seeing this, please open a Tech Support case and specify the product as Windchill PDMLink and technical area as Functionality. They will get back to you ASAP.
Thanks!
There is a property that enables all ACLs.
Can temporarily set it to false, restart, fix the ACL, then set back. I believe the property is something like wt.access.enabled.
Hi Nikita,
I agree with suggestion given by Mike. Set the following property to false in wt.properties to disable all the ACL's and remove the wrong permission. Once done you can reset the property.
wt.access.enforce
Let us know if that resolves your issue.
Bhushan
