Need complete software compatibility matrix
MCoe
I need a complete software compatibility matrix for Pro/Intralink 3.4. All I can find are half baked documents that reference everything but the version of Intralink I am running (3.4(M012)). I need to know where to find the ProE version that will work with it. We are running ProE 3.0 (M022) and it does not work with this version of Pro/Intralink. This is a post Intralink upgrade after desaster recovery.
I have seen these documents. http://www.ptc.com/WCMS/files/24313/en/SWCompatibility34061809.pdf does not tell me anything about Pro/E Wildfire 3.0(M022). This is what we are running and it worked with Pro/Intralink 3.3(M021). The document does reference Pro/Intralink 3.4(M012) but that table does not include Pro/Engineer Wildfire 3.0. So, am I to guess that if it is not in the table it is not compatible? I don't like to assume.
The other document http://www.ptc.com/WCMS/files/67180/en/ProECompatibilityRoadmap09242009.pdf states that Pro/Engineer Wildfire 3.0 is compatible with Pro/Intralink 3.4 and links to the previous document for details (circular reference).
I still need to know what versions of ProE are compatible with Pro/Intralink 3.4(M012).
After upgrading to Pro/Intralink our users cannot open any items that have been previously checked into Intralink. When they attempt to do so an error is generated.
"Cannot lauch the external application "loadnpro" This can happen if external application is not found or incorrect parameters are passed to the application."loadnpro" application is used by Pro/Intralink to communicte with Pro/Engineer which must already be running.."
it is access deny, can anyone help? I register already
