Need to work on multiple Creo or projects simultaneously with windchill
bbalan
2-Explorer
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030
I need to work in multiple Creo or multiple projects with windchill, How it is possible
While opening the second session first session is automatically closing
avillanueva
23-Emerald I
(To:bbalan)
Check out this article which might be similar to your post. If you can expand a bit on your situation, that would be great.
https://www.ptc.com/en/support/article/CS202061
Are you using multiple servers or just need to run multiple workspaces at the same time in different Creo sessions on the same machine?
Hi @bbalan,
Anurag
