New CAD Document start part
cdavidson
8-Gravel
When creating a New CAD Document, the field Template Name has two choices, neither of which is my start part. How do I get my start part as a selection in that field?
soerton
(To:cdavidson)
1. As an org admin, Activate/create organization level workspace called Templates.
2. Import the CAD template to the Templates workspace.
3. Rename template to New_<filename> & check in
4. Under the org level, select Templates
5. Select New CAD Template
6. Search for the template by name in the CAD Source field. ie - New*
7. Set the template name & File Name as well as any default attribute values. (NOTE that the file name is the value displayed in the drop down list)
8. Verify this template is set to Show on the template list.
soerton
(To:cdavidson)
Thanks Stephen! That worked perfectly!
