New WT Part Create & Load
Amirtharaj_K
Hi Everyone,
Actually i already have a part master number list in excel (only number), i want to create the WT Part from excel. I heard we can use the loader to create WT Part. I need a some example how we can load. I found a related document i didn't understand the .csv creation and as well as convert into xml. Please help me on this.
Fadel
22-Sapphire I
(To:Amirtharaj_K)
8 REPLIES 8
Fadel
22-Sapphire I
(To:Amirtharaj_K)
Hi ,
the part creation tool is used for system migrated from a CAD  centric plm like Intralink to bulk create related parts for existing CADs.
for your scenario I will rather use the import from excel .
you can create a dummy part manually and use export to spreadsheet to create a  excel model .
Later you can copy that model row with other numbers and change any attribute if needed like name .
Fede
Amirtharaj_K
(To:Fadel)
Hi Mr. Fadel
Apologize for the delay in response.
I add the new number in the export excel sheet after that I create a new number in the same sheet to import the spreadsheet into Windchill it's created. I want to test more on this. Thank you so much for showing me how to do it.
Thank You,
Fadel
22-Sapphire I
(To:Amirtharaj_K)
thanks for info , good luck
Fede
Anand_G
(To:Fadel)
Is it possible to have the attachment also can be uploaded through this import option ?
Fadel
22-Sapphire I
(To:Anand_G)
not using excel , you have to use loadfromfile , see attached example
Next time kindly open a ne topic , to keep each request/solution documented separately
Fede
Amirtharaj_K
(To:Fadel)
Thanks, Mr. Fadel, Can you Share the document, which I need to follow to create a LoadFile? Above .xml test.zip is there I didn't know what kind of xml is used. If you are okay means I can create a new case for this.
Warm Regards,
Amir
Fadel
22-Sapphire I
(To:Amirtharaj_K)
Amirtharaj_K
(To:Fadel)
Thanks, Mr. Fadel. I thank you from the bottom of my heart because I have learned more from you. Way of teaching, explaining, supporting documents, and videos for me.
Once again, thank you for your support.
Warm Regards,
Amir
