No Site Level Access
dgschaefer
OK, I must be a moron or something.
Here's the deal. We're attempting to get our feet wet with WC10 prior
to laying out 5 figures for a consultant to set it up for us. Foolish?
Perhaps, but that's the deal.
So we've got it installed and I was setting up a few users. I decided
that my user names ought to better reflect their roles, so I renamed the
org admin for the main 'Design Central' org to 'DC_Admin' and org admin
the 'test' org 'Test_Admin'. Clever, right?
Then I decided, because I'm OCD or something, to rename my site admin
from 'Administrator' to 'Site Admin'. WC throws an error and says I
don't have permissions or something. Whatever, I cancel out of the user
edit screen and try to go back to the Participant Administration screen.
I get a message that that area or object or something doesn't exist.
Frustrated, I decide to log out and log back in. I close IE and login
with my site admin credentials and I get logged in fine.
But ... I no longer have the 'Site' or 'Organizations' icons in the
browser pane, essentially my one and only site admin login can no longer
administer the site. Yay.
So, what did I do wrong here and, more importantly, how do I fix it?
Doug Schaefer
LinkedIn
Look in the guides to disable access policy in wt.properties and you should be able to get in that way. If that doesn't work you probably find it faster to start over and wipe away then reinstall.
Sent from my Verizon Wireless BlackBerry
Doug,
Try setting the property wt.access.enforce=false in the wt.properties &
propagate the same.
Restart windchill and then undo the change you did for site admin user
name.
Best Regards
Rajesh Balasundaram
Just to add a bit of the "why" on this to others correct recommendation to temporarily disable access control...
OTB, the install allows only this user to be Site admin (from wt.properties).
[cid:image001.png@01CCE662.5A87BB50]
