I've got one additional response, see below. Thanks for the input.
Hugo.
<< ProE WF3 M190 - PDMLink 8.00 M040 >>
I see it as somewhat similar to “smart” part numbering, which I highly recommend not doing.
BUT, I think this is not a bad practice what you show below, but I wouldn’t take it much further – in other words I wouldn’t try to describe the document any further than that . . . . that’s a rabbit hole you don’t want to go down – that’s of course why you have attributes to help describe things (and hence don’t need “smart” numbering).
Recently I had a customer mention changing the numbering of Change Tasks to be “WTXXXXX” because it was kind of confusing to see another number inside the ECN, especially since the numbers were very close to each other (though that would change over time as they processed more and more).
In retrospect, when I was a Windchill Admin, I probably wish I had done just a little more of what you describe below, if nothing else it is a huge training aid so that when people see all these new types of objects flying by them it’s at least obvious at first glance WHAT it actually is – it’s difficult to tell inside of Windchill sometimes if you are looking at an ECR, ECN, Promotion Request, etc. so I kind of like what you show below. I personally don’t see any negatives as long as you don’t go much further with it.
