Old WTPart Revision creation in existing WTPartMaster
Mathivanan
6-Contributor
Hi team,
Lastest WTPart and related WTPartMaster already available in windchill. we need to create new old revision of the same WTPart.
ex.
Existing Part Master - AB12CD and available WTpart revision in the partmaster is 3.2
need to create old Part revision - 0.1, 1.1, 2.1
i try to revise the lasted part and set the revision to the old revison getting below error
Error:
Cannot change revision of Part - AB12CD, NEWREVDATANAME, ORGNAME, 4.1 (Engineering) to target revision 2.
Please share any API or Java code to create the old revision for the existing part.
Mathivanan
This article points you to using load from file method: https://www.ptc.com/en/support/article/CS192244?source=search I think the steps would be the same for WTParts as with WTDocuments.
You used to be able to use "Insert" method to load a previous version but no longer. This is a critical part of system and data integrity to test test test.
The loading Guide (https://www.ptc.com/support/-/media/support/refdocs/Pro_INTRALINK_8,-d-,x/11,-d-,0/WCDataLoadGuide_169024.pdf?sc_lang=en&source=search), page 17 explains what you need to be concerned with:
More About wt.part.LoadPart.beginCreateWTPart The method wt.part.LoadPart.beginCreateWTPart supports versioning. This allows a part to be created at a specified version and iteration. Multiple part versions imply a sequence. For example, subsequent bulk load runs can fill in the gaps, but they do so by attaching to the latest iteration of the previous version. If a newer iteration is added to the previous version, the new version is attached to the new latest iteration. For example: Load set 1 (E.1, A.1, C.2) results in (A.1, C.2, E.1). The predecessors of: C.2 is A.1, E.1 is C.2. Load set 2 (B.1, A.2, C.1, C.3) results in (A.1, A.2, B.1, C.1, C.2, C.3, E.1). The predecessors of: B.1 is A.2, C.1 is B.1, E.1 is C.3. The iteration history of B.1 shows both A.2 and A.1 The iteration history of C.1 shows B.1, A.2 and A.1 The iteration history of E.1 shows C.3, C.2, C.1, B.1, A.2 and A.1 Any new versions or iterations that are added continue to change the predecessor links to the new latest iteration of the previous version.
Hi @Mathivanan ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
