Bill,
Alexius is right. Done it, suffered but you have to follow everything step by step.
Chris
Hi Bill,
Did you export the TargetConfigBranch node from the 9.1 before you imported the 8.0 LDAP? The process is to export the TragetConfigBranch of the 9.1, and also backup the entire 9.1 LDAP, then import the 8.0 root LDAP, delete the dc=com node above the ou=people node in the 8.0 LDAP, and then import the TargetConfigBranch for the 9.1 into the LDAP just like doing a rehost, this way it will add the new node EnterpriseLDAP to the LDAP structure. I think what is happening is that your 9.1 system is looking for the TargetConfigBranch node specific to 9.1 and find the 8.1 TargetBranchConfig node instead. If you have backed up your 9.1 root LDAP, you can reimport that, then do the export of the 9.1 TargetConfigBranch, and try again. Also you might need to look that the PTC upgrade guide, it spells out the entire process if you are doing an upgrade.
HTH
Alexius C. Chukwuka
IT Analyst, PDP Systems
John Deere Power Systems
Product Engineering Center
*Voice: 319-292-8575
*Mobile: 319-429-5336
*FaxFax:319-292-6282
*E-Mail: -
CONFIDENTIALITY. This electronic mail and any files transmitted with it may contain information proprietary to Deere & Company, or one of its subsidiaries or affiliates, and are intended solely for the use of the individual or entity to whom they are addressed, shall be maintained in confidence and not disclosed to third parties without the written consent of the sender. If you are not the intended recipient or the person responsible for delivering the electronic mail to the intended recipient, be advised that you have received this electronic mail in error and that any use, dissemination, forwarding, printing, or copying of this electronic mail is strictly prohibited. If you have received this electronic mail in error, please immediately notify the sender by return mail.
