Does anyone know if PDMLink 9.1 can be configured to sequentially pick new part numbers from a list stored on the server?
Hi Bill,
Thank you for the reply.
To clarify, I would like the system to select new part numbers from an external file on the Windchill server that contains a range of pre-defined part numbers.
HI
I will not add more technical info on this as it has all been said.
We have configured our Windchill server to pick a number from a list from a txt. This works very well. This was in 2008. Hoping that any new ERP we will use later as global ERP will be capable of this too but that is not possible. SAP can't
so until we bridge the two systems we have 2 masters for number allocation. Not ideal.
Best regards
