PDMLink - Reassign Change Notice
ptc-171472
While I'm waiting for PTC Tech Support to call me back...
We are using PDMlink 9.1 M020 and we are using the Change Notice module
Once a user has created a Change Notice, is it possible to reassign it
to another user?
A user has gone on vacation, his manager sent a Change Notice he
submitted for Rework.
We need a different user to update and resubmit.
I can't seem to figure out how to do that.
Can it be done?
Or do I delete the change notice and have user B create a new one?
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
5 REPLIES 5
We do this every day - by editing the Change Notice / Change Task team(s).
avillanueva
(To:ptc-171472)
Or from the assignments link in the Product, there should be a reassign
action.
Reassign is best if only context manager / admin needs to do this. If you others to be able to do so, editing the team allows. Need to give those users Modify permission to the Team object. Downside of this is that they can edit all teams at all times.
Each has pro's and con's.
Thanks! For some reason, I didn't think that the CN's showed up in the
assignments.
Michelle McMasters
Michelle,
Check going into the Product or the Context Assignments in which the CN
is created.
Also, check the Current View is set to Open. You can then check next to
the task and click Reassign.
As a future thing, you may want to train your users on how to use the
Calendar Delegation function inside Windchill.
Rekha.
