PDMLink Viewables
ptc-171472
PDMLink Viewables
We recently migrated to Windchill PDMLink 9.0 and are re-launching with
9.1 in a week
Our pre-PDMLink process required the creation of PDF's which were
published to a network location that our non-engineering users could
access to view our released drawings by accessing the PDF.
Our intent was to have PDMLink push a Production PDF to the network
location during the Change Notice process. The CN is approved, a PDF is
created and saved on the network.
We also intend to use ProductView for markups. You open a drawing in
ProductView and can markup the drawing, save to PDF and the object
becomes an associated file to the source drawing.
Apparently these two goals are counterproductive. If you out put a PDF,
you cannot mark it up in ProductView. The hpgl out put that ProductView
needs for mark ups is not a PDF. Converting the hpgl into a PDF seems
to be a challenge.
Is anyone else dealing with this type of issue? Do you create PDF's of
your drawings for publishing? Are you using ProductViews mark up tool?
Any suggestions how to make these two actions compatible?
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
rpassolt
(To:ptc-171472)
Hi Michelle!
Afew customers are publishing their primary productview viewable as a PDF and then use productview to mark it up. Some don't like the PDF mark up within productview so they have bought the PDF Collaboration piece to solve this (and other things).
I can touch base next week with more detail.
Rick
Rick Passolt
<u>www.fishbowlsolutions.com</u>
