Hi all,
I'm attempting a purge of our off-the-shelf library parts in (unfortunately) Intralink 3.3. The criteria is set to all except latest 1.
Since 90% of them are family tables, I get conflicts, some that are non-overridable. Tech support said that you cannot delete old versions of tables if they are reporting to an assembly, and that I should do a where-used on all the parts with conflicts and remove them from where they report to, which is the most ridiculous thing I've ever heard. Unless anyone knows of a work-around, it looks like tables are not able to be purged the same way as stand-alone parts. True?
Stefan
[cid:image001.png@01CA27F5.D0E43D10]
