PDMLink created on date in a Creo drawing for revisions
sarmstrong
I want to use the PDMLink created on date to automatically populate revision dates in our revision block.  The problem is that if a new revision is created the date changes to the latest date.  How can we make the date revision specific?
TomU
(To:sarmstrong)
You can't.  It will have to become either dumb text or be linked to a Creo parameter that does not change (containing dumb text).
BenLoosli
(To:sarmstrong)
You can capture the date in a revision specific parameter and use that in your revision block.
if revision == '1'
Revision1_date = EXTRACT(PTC_WM_CREATED_ON,1,10)
else
if revision == '2'
Revision2_date = EXTRACT(PTC_WM_CREATED_ON,1,10)
else
if Revision == '3'
Revision3_date = EXTRACT(PTC_WM_CREATED_ON,1,10)
endif
etc....
Then use the &Revision#_date in your table for each revision.
Ben,
So I will need to add these parameters in my models correct?
Scott
BenLoosli
(To:sarmstrong)
Yes, we had something similar in our start parts.
We captured the initial created date and user initials.
You may want to use modified_on rather than created_on. Created _on does not change when you revise a part from 1 to rev 2.
