PTC/User Webinar: Philosophy of Product Structure #2 --- Questions
hpomerene
7-Bedrock
Post questions here from Philosophy of Product Structure webinars.
Questions will be answered in a follow-on webinar
What's your opinion on View Versions? New model does away with the double revision (A goes to A.-) and uses a single letter. However, it no downstream view existed, it starts at beginning of the series. Example if I have Part version -, A, B, and C, then I create the first Manufacturing view version off C, it creates it at version -. This appears to me to be very confusing. Have you come across this? Is it an issue and how have you solved this?
Can you talk about CAD-driven BOM Structure? What is it? How does it work? Best practices to implement it?
