Packaged scripting (SQL, QueryBuilder, Info*Engine) for capturing Windchill Content Download Count and Content Download Size for EPMDocument and WTDocument
habat
We are wondering if anyone can share a packaged scripting (SQL, QueryBuilder, Info*Engine, PSM Extension...?), for capturing Content Download Count and Content Download Size for EPMDocument 3D, EPMDocument 2D and WTDocument Items which were created over a particular period of time (daily, weekly or a specific range of hours, ...)
This is for monitoring purpose and this can be finally embedded within either (or both) PSM and WBR (Windchill Business Reporting a.k.a Cognos)
satre-2
(To:habat)
Download any content from windchill is one event (Read Content) which you need to enable.See below article for details
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS135740&art_lang=en&posno=1&q=configAudit.xml&source=search
If event is enabled then each time when you download the Document (it includes opening document in CAD Application or publishing  document in CAD worker ) event is recorded in auditevent and auditrecord table.
Enabling this event recording may put some additional load your database
Shreyas
habat
(To:satre-2)
Shreyas - Seems interesting. Is there a way to consider Event splitting (segregated reporting) for considering three distinct categories with:
#1. EPM Document 2D content
#2. EPMDocument 3D Content
#3. WTDocument content?
BineshKumar1
(To:habat)
Herve,
There is a column in security audit report for download, Object Identity - this will have the type of object downloaded  say CAD document, WTDocument, Markup. The good thing is it will even let you know the softtypes as well.
If you download or open a top level assembly, it would log only one event for the asm which you chosen, not all the child parts
These are the column headers if it helps
Event Label
Event Key
Event Time
User Name
User ID
IP address
User Organization
Object Type
Object ID
Object Type Branch ID
Object Name
Object Number
Branch ID
Working Branch ID
Version
Master ID
Organization ID
Organization Name
Context ID
Context Name
Context Type Branch ID
Folder Path
Domain Path
Identity
Lifecycle State
Transaction Description
Object Identity
Security Labels
Event Specific Data
Thank you
Binesh Kumar
BineshKumar1
(To:habat)
As for the PSM. you have two business transactions OOTB
  1. Content download by User Name
  2. Content Download by Database ID
Owing to different download mechanisms, PSM cannot capture the username for all the transactions. In that event it captures the database id. A combination of results from the both the reports would give an accurate picture on download. To interpret the username from id a, qml has been provided which queries the wtuser table. - http://www.ptc.com/WCMS/files/142899/en/User-Name-Report.zip
Thank you,
Binesh Kumar
