PartsLink reload cmd
jenglish
windchill com.ptc.windchill.partslink.AdminApp -reload
As anyone experienced pagingsession errors running the above command? The difficultly we're running into is that the reload quite consistently fails on our production system but rarely fails on our cloned dev/qual environments.
PTC has asked us to update the values of
wt.pom.paging.fetchLimit=15
wt.pom.paging.fetchSleepInterval=1000
wt.pom.paging.pagingSessionLimit=5
wt.pom.paging.sessionCleanupTime=1800
The changes to wt.pom.paging.fetchSleepInterval (1000 to 3000) seems to allow the reload command to (most of the time) execute on our devl/qual systems - doesn't help much on production.
What version of Windchill and M-build are you using?
We have used PartsLink for 9.1 and 10.0, both, currently running 10.0 M020
with a lot of patches. If you are on 10.0, we can share our settings for
the ones you list, below.
Al
[solutions] - PartsLink reload cmd
English, John M (US SSA)
