Pass JSP Form values to ForomProcessor
Manoj_Dokku4
11-Garnet
I have a requirement where, when a form from JSP is submitted from the JSP page in windchill, all the values from the form has to be retrieved and populated in the FormProcessor.
@HelesicPetr
1 ACCEPTED SOLUTION
Hi @Manoj_Dokku4
All inputs from page are usually populated to a NmCommandBean object.
From the commandBean object you can retrieved all html inputs from the wizard or page.
eddited>
that's not correct,
Only wrapers can be retrieved from nmCommandBean
<%@ taglib prefix="wrap" uri="http://www.ptc.com/windchill/taglib/wrappers" %>
So you should use wrapers as a input in your JSP page
<wrap:textBox name="filterName" id="filterName" value="" size="50" maxlength="100"
onkeypress="filterNumberenter(event)"/>
You just need to find where your inputs are stored.
input types>
text, radio, checked, textArea, comboBox  and so on.
You can retrieve the types by functions get....
HashMap textArea nmCommandBean.getTextArea()
HashMap checked = nmCommandBean.getChecked(); // if something is not checked it is not included in this Hash
HashMap radio = nmCommandBean.getRadio();
HashMap texts = nmCommandBean.getText();
HashMap comboboxes = nmCommandBean.getComboBox();
you need to process all your inputs from this HashMaps each input should own identification from JSP.
hope this can help
PetrH
Hi @Manoj_Dokku4
eddited>
that's not correct,
input types>
hope this can help
PetrH
