Right - it applies to anything that is on Affected or Resulting data.
By default the indicator is shown when the lifecycle state of the CR/CN goes
to Implementation, but that is controllable via property setting -
wt.change2.pendingRequestStates
wt.change2.pendingOrderStates
Separate values with a ",". The default is IMPLEMENTATION
Add those to wt.properties if you want to change the OOTB states.
z
On Fri, Nov 20, 2009 at 2:16 PM, Chukwuka Alexius C <
-> wrote:
> Mike,
> I think the Pending Changes icon appears as soon as the object is put on a
> change such as ECR,ECN, CA ( affected and resulting items tables).
> Thanks
