Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Nicolas I don't know a way to do exactly what you're asking for (should't be hard, but that's not my domain), but I'd suggest using "Saved Searches" if you didn't before. It would be faster than choosing CAD Document type every time. You also could add some additional "default" search criterias.
