Version: Windchill 12.1
Use Case: Options & Variants
Description:
In Option Pool i want to create a New Option but getting a persistance error as soon the New Option has been given a name, is that SQL DB related??
i have found a solution, my sql db on filegroup indx is full and i need to empty it. because i am using sql express
Hi @EC_10581209,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
I do not know much about Options and Variants but the method server log of this event might have more information. Can you look for that?
