Problem when uppgrading from WQS 10.2 to WQS 10.2 M060
Newbie
Hello
I have uppgraded from WQS 10.2 to WQS 10.2 M060 and everything works perfect except that Bold text in input forms that I have created dosen't show up as bold when I use them through the Webb login. If I use the installed client and edit the input forms I can see that the text is Bold. Where can the problem be, should I look in the IIS or in the forms or is it some configuration setting in WQS?
