Problem with access to LDAP Server via Info*Engine Administration
belandadi
Hi all,
  • Customer is not able to access access LDAP Server via Info*Engine Administration after changing the Port number  (as described in CS50496) / Error : "Unable to connect to the LDAP server".
  • Windchill DS is accesible using the same crindentials !!
  • In the logs, the following error is observed : "wt.system.err wcadmin - javax.naming.CommunicationException: kdbs0043.kdbw2k.br:389 [Root exception is java.net.ConnectException: Connection refused: connect] "
Anyone knows if there is any further changes that should be done besides that ones described in the above article  and how to resolve and investigate this issue further ?
Arshad
(To:belandadi)
Hi Badr,
Did you added the updated port number in the Base URI, at the Info Engine administration page for example :
 ldap://kdbs0043.kdbw2k.br:<updated_port>/dc=kdbs0043.kdbw2k.br,dc=.....
Arshad
(To:belandadi)
Hi Badr,
belandadi
(To:Arshad)
Thank you for the reply. Yes, I already resolved the issue using the same suggestion.
Thank you for your attantion. I'll mark this as accepted resolution so it can help other poeple.
