Hi all,
Anyone knows if there is any further changes that should be done besides that ones described in the above article and how to resolve and investigate this issue further ?
Hi Badr,
Did you added the updated port number in the Base URI, at the Info Engine administration page for example :
ldap://kdbs0043.kdbw2k.br:<updated_port>/dc=kdbs0043.kdbw2k.br,dc=.....
Hi Badr,
Thank you for the reply. Yes, I already resolved the issue using the same suggestion.
Thank you for your attantion. I'll mark this as accepted resolution so it can help other poeple.
