I've got three different Windchill systems that I am trying to move my users over to Microsoft AD. I have test systems for two of them. These are Windchill 11.1 systems. One I have set up and users can login. The other one, I have set up and I can find users, add them to Windchill, give them groups and licenses but then the users cannot login. I can still login as wcadmin, but wcadmin is still in WindchillDS. Instead I get this error and a never ending login box.
AH01617: user <user name>: authentication failure for "/Windchill/app/": Password Mismatch
Both systems are pointing to the same server to access Microsoft AD. Has anyone encountered this and have a fix or what to look for?
Thank you,
Brian
Check Apache app-Windchill-AuthProvider.xml file have correct provider entries.
Thank you. I went back and I had made one mistake. Sometimes when you look too hard you miss the one little thing.
