I would like to create a report using the Query Builder (Windchill 10.0 M030) that lists all the resources and the project they are linked to. It could look like this:
| Resource Name | Project Name |
| Resource 1 | Project 1 |
| Resource 1 | Project 2 |
| Resource 2 | Project 1 |
| Resource 3 | Project 3 |
Thank you !
Hello Florent,
were you able to solve this issue. If yes, is it possible to share the details.
Regards
Syed
Hello Syed,
if you haven't already done, I suggest you to join this group Reporting and to take a look at this document Resource for reporting
In this document you can find some helpful information about reporting and also lots of report ready to use.
Maybe you won't find what you're looking for, but I hope it can helps you.
Thank Marco for the response. I am already aware of the above resource. Somehow the report shows blank after generation. So wanted to check if this worked earlier.
