Promoted On
bwilson-2
8-Gravel
Promoted On
If I go to the Maturity history of an object I can see the "Promoted On" column. I would like to see this column in the standard folder table instead of "Last Modified" anybody got any thoughts.
Brian
Someone else recently asked this. You need to basically make that attribute available for selection on lifecycle managed objects.
You have to be able to edit logical attrubutes xml file if a reference cannot be found.
You then have to edit the AvailableAttributes.xml file and add the logical identifier to that list. It is what is used to make tables configurable.
Worst case, you may have to specify a data utility for it in the jsp for general/netmarkets and/or search table descriptors.
Sent from my Verizon Wireless BlackBerry
I'm running PDMLink M050 and I have two environments. In one
environment (from the general IE browser), when I add components to a
workspace it automatically takes me to that workspace. In the other
environment (from the general IE browser), it leaves me in the Info
window about the assembly I just added to my workspace ~ doesn't bring
me right to that workspace. I'm assuming that is a preference setting,
but I haven't been able to find it. Does anyone know?
Thanks, John
This electronic message including any attachments ("Message") may contain information that is privileged, confidential and/or exempt from disclosure under trade secret and other applicable law. If you are not the intended recipient, notify the sender immediately, permanently delete all copies of this Message, and be aware that examination, use, dissemination, duplication or disclosure of this Message is strictly prohibited.
