Publish into a workflow
aemaeth.2501
I would like to publish a WTDocument in a workflow expression.
For the moment I use doPublish(..) method of
com.ptc.wvs.common.ui.Publisher, but no item is added to the Publish
Monitor.
Any help would be greatly appreciated.
Sincerely,
Thibault Magné
This is the snippet of the code that I used for one of our projects. Make
sure you are capturing the exception and logging them so that the stack
trace will show you the reason for failure.
public static void performPublish(WTObject wto) throws
WTException, PropertyVetoException {
wto = (WTObject)
ContentHelper.service.getContents((ContentHolder) wto);
Vector vector =
ContentHelper.getContentListAll((ContentHolder) wto);
if (vector != null) {
boolean flag1 = true;
for (int iContentCount = 0;
iContentCount < vector.size(); iContentCount++) {
ContentItem
contentitem1 = (ContentItem) vector.elementAt(iContentCount);
if
(contentitem1.getRole() != null &&
!contentitem1.getRole().equals(ContentRoleType.PRIMARY))
continue;
boolean
flag2 = processDocumentContent(wto, contentitem1, flag1);
if (flag2)
flag1 = false;
public static boolean processDocumentContent(WTObject wto,
ContentItem contentitem, boolean flag) {
boolean flag1 = false;
if (wto instanceof WTDocument) {
String as[] =
DocumentHelper.getWorkerForContentItem(contentitem);
if (as[0] != null || 1 < 2)
String s =
as[1];
Publish.doPublish(false, true, wto, null, null, flag, s, null, 0,
"<wvsoptions>documentFile=" + s, 2, null);
flag1 =
true;
return flag1;
HTH
Thank you and have a great time.
Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email); 909 800 8423(M); 973 324 2729(W); 866
908 6561(F);
That works perfectly !
Thanks so much.
Sincerely,
Thibault Magné
> Make sure you are capturing the exception and logging them so that the
> stack trace will show you the reason for failure.****
> WTException, PropertyVetoException {****
> wto = (WTObject)
> ContentHelper.service.getContents((ContentHolder) wto);****
> Vector vector =
> ContentHelper.getContentListAll((ContentHolder) wto);****
> if (vector != null) {****
> boolean flag1 = true;****
> 0; iContentCount < vector.size(); iContentCount++) {****
> ContentItem contentitem1 = (ContentItem) vector.elementAt(iContentCount);*
> if
> !contentitem1.getRole().equals(ContentRoleType.PRIMARY))****
> continue;****
> boolean
> flag2 = processDocumentContent(wto, contentitem1, flag1);****
> if (flag2)
> flag1 = false;****
> ContentItem contentitem, boolean flag) {****
> boolean flag1 = false;****
> if (wto instanceof WTDocument) {****
> String as[] =
> DocumentHelper.getWorkerForContentItem(contentitem);****
> 2) {****
> String s =
> as[1];****
> "<wvsoptions>documentFile=" + s, 2, null);****
> flag1 =
> true;****
> return flag1;****
> HTH****
> Thank you and have a great time.**
> Best Regards**
> * Swamy Senthil***
> * Principal Solutions Architect, **Swasen Inc*****
> 908 6561(F); ****
> *From:* Thibault Magné [
