Dear all,
In my Windchill 11.0 environment i have a publishrule who creates additional file if it is a released drawing.
that works for "set state" and "promotion request" with the <publish on="unknown-source"
I have tried to do the same in an older 10.1 environment.. (I know it's not supported anymore.. and no, i can not update to a newer release now :-))
unfortunately rules are not evaluated for promotion requests. but it works fine for set state.
Does anyone know this behavior?
is <publish on="unknown-source" in 10.1 not the same as in 11.0?
Best regards to all
Daniel
Not sure about "unknown-source" in 10.1, but I don't think the additional files were added until 10.2.
Thanks Tom
Hi Daniel,
In this moment, I configure the connection between Illustrate and Windchill.
The connection is up : I can generate the pvz file for each CAD check-in.
To limit the vault size, I will reduce the publish event of the pvz file to a list of state (ie Released or Prototype) : this change car occur after an promotion request, or a manual setstate
Could you explain me how you can generate the custom publishrule to manage it ?
Vincent
