Query Builder. Multi BOM Level for CAD structure
cc-2
Hello
in the information page of a CAD structure, looking at the CAD structure it is possible to click on the button for Multi Level BOM.
This gives a table where the first column is Level and it indicates in which level of the BOM each line is.
We are trying to capture this in Query Builder
We are trying to get a report showing for each assemblies.
level filename number
We can get all the asm, filename, number but we cannot find where Level is.
Any idea
Windchill PDMLink 9.1 M050
Thank you very much for any help
Level is not anattribute in the usage link table. It is a value calculated based on the depth of a component from the parent assembly. I believe you will probably need to have a custom XSLT file to calculate this for a QueryBuilder report.
Ravi Dharmalingam
ProductSpace Solutions Inc.
I don't believe you will be able to get a multi-level bom out of QueryBuilder. In 9.1 (which you indicated you are on) can't handle recursion, which is necessary to generate a multi-level bom.
Steve D.
cc-2
(To:cc-2)
Hello
thanks for your reply.
Sorry for my ignorance but was is XSLT
thanks
Best regards
