Hi All,
Can anyone tell me the SQL Query to get all the IBA names of an object type ?
Say for WTPart or for its subtypes if we wish to get all the IBA's of that object type how will we get it ? Can anyone tell me that SQL query so that I will run once in SQL Developer and see the same.
Thanks in advance.
Best Regards,
Aditya Achanta
Aditya Achanta wrote:
Hi All,
Thanks for the input.
In fact it was useful to me.
But if this is the case like for a WTPart I had created a subtype called as "DemoPart" and for that DemoPart I had created an attribute or an IBA called as "DemoAttribute".
How do i retrieve the details of that IBA using an SQL Query in SQLDeveloper.
Can you please let me know about it once ?
Thanks and Regards,
Aditya Achanta
Given the following conditions
Then you would do the following
Query would then be something like this:
select
wtm.wtpartnumber,
wtm.name,
wt.versionida2versioninfo || '.' || wt.iterationida2iterationinfo Version,
wt.ptc_str_1typeinfowtpart DemoAttribute
from
wtpartmaster wtm,
wtpart wt
where
wtm.wtpartnumber = '12345'
and wt.ida3masterreference = wtm.ida2a2
and wt.statecheckoutinfo = 'c/i'
order by
wt.versionsortida2versioninfo,
Hi All,
Thanks in advance.
Best Regards,
Aditya Achanta
If you are referring to custom attributes I don't have an exact query however I have a link to a previous thread that will get you started:
Randy, on the referenced link, is this line specific to your system?
"and tdef.ida2a2 = 144505"
No. That is an example (actually from David...). The '144505' would come by looking at the lwctypedefinition table to get the appropriate ida2a2.
Hi All,
Thanks and Regards,
Aditya Achanta
Hi All,
Thanks and Regards,
Aditya Achanta
select
wtm.wtpartnumber,
wtm.name,
from
wtpartmaster wtm,
wtpart wt
where
order by
Try with below query. if your attribute is of string type
select sd.DISPLAYNAME, VALUE from STRINGVALUE sv, STRINGDEFINITION sd
where sv.IDA3A6=sd.IDA2A2 and ida3a4= WTPartIDA2A2
SQL is
select wtmas.WTPartNumber, wt.versionIdA2versionInfo, wt.iterationIdA2iterationInfo, wt.statestate, sd.displayName, sv.value, sv.value2
from WTPartMaster wtmas
join WTPart wt on wt.idA3masterReference = wtmas.idA2A2
join StringValue sv on sv.idA3A4= wt.idA2A2
join StringDefinition sd on sv.idA3A6 = sd.idA2A2
where sd.displayName = 'AttributeName'
order by wtmas.WTPartNumber, wt.versionIdA2versionInfo, wt.iterationIdA2iterationInfo
join StringValue sv on sv.idA3A4= wt.idA2A2 join StringDefinition sd on sv.idA3A6 = sd.idA2A2
