Version: Windchill 12.0
Use Case: Using REST, I can start with a known ID for a WTPart, and find the documents that are linked to the part using /ProdMgmt/Parts/References. When starting with a known document ID, I cannot find an endpoint that will allow me to get the Referenced by Parts, even though using the UI, I can see them.
Description:
Is there an Endpoint for getting to the Referenced by Parts data, using standard end points, or am I stuck looking at a custom endpoint, or modifying an existing one?
Hi @sblaske
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
