Hello .
I have a site that is using PDMLink 9.0 M040. They have recently started to use RSD (Routed System Designer). They installed the Workgroup Manager for RSD, etc...
However.
They can NOT check in to a Product. They can ONLY check in if they log in as a Product Manager. Pro/Engineer, Documents work perfectly with the Product.
Question:
Is it an access control issue? Does the ECAD WGM make a new Type that they need to create access controls for?
Brian Sullivan
(PS they do have Folder Level Domains in use)
