Re: Trying to install WC10.1 with a remote SQL server.
Vipul
As per this thread - same issue
Hi
I am also facing the same issue can you please tell me how you solved it.
I am using SQL 2016 with named instance,
I have installed SQL on machine 1 and also ran 12.o.2.o psi and sql server on machine 1.
then on machine 2 which is my windchill server when i am running the psi how can i give the path of machine 1 and i am not able to give following path
Thanks in advance for the help
Vipul
(To:Vipul)
Issue resolved at my end.
Vipul
(To:Vipul)
