Version: Windchill 13.0
Use Case: When trying to create a new representation in Windchill SIM using Arbortext Publishing Engine, I continuously receive the "Can't find reference post processor" error in the BGMS logs, and the book output cannot be generated.
Description:
I reviewed the PE logs and observed some Java-related errors. Subsequently, I removed the APTJAVAVMPATH environment variable and used javaselect.exe to define the correct path.
For the "Can't find reference processor" error, I updated the stylesheets.
I did not encounter any errors in PE Interactive.
I also tried publishing a few different books with different stylesheet files, and I didn’t encounter any issues.
Thank you for your response, dear Marco. I tried the article, but my style sheets are still not updating on the PE, and I continue to receive the same error. After the style sheets are updated, should I remove the .bak files from the same location?
Hi @EY_12187085,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
