Regular expression for required iba value
  • February 9, 2017
  • 0 replies
  • 997 views
I'm trying to make a attribute dependent of the value of another attribute.
Both are IBA's.
So we have an attribute "number of bends" this is filled in automatic with a string number.
The second attribute "overrule qty" should be required if the other one is greater than 0.
So I tried to do it like this:
But this doesn't seem to work, my guess is that number of bends is defined as a string and not as an integer, but this we can't change that easily.
Does somebody know a trick to do this, or another way to get my goal?
Thanks in advance
