Rehost Windchill with existing Data base
Milan
9-Granite
Version: Windchill 11.1
Use Case: Application server required to be replaced. Hence, planning for rehost to a new server machine, indenting to use same data base.
Description:
Can we use existing data base [Reuse data base] for the rehosting? or data base need to be duplicated for the rehosting?
What are the risks involved to reuse existing data base for rehosting Windchill to a new environment, if any?
What is the best practice to achieve this use case?
FT_11575036
(To:Milan)
Re hosting an application server while reusing the existing database can be a viable approach, but it comes with certain considerations and potential risks. Here are some insights and best practices to help you with this process: Can you reuse the existing database? Yes, you can reuse the existing database for rehosting. This approach can save time and resources since you won’t need to duplicate the database. However, it’s crucial to ensure that the new server environment is compatible with the existing database. also risks ensure that the new server’s operating system, database management system (DBMS), and application versions are compatible with the existing database schema and data.
Hope that helps.
avillanueva
23-Emerald I
(To:Milan)
Yes, you will able to use the same database. This document describes the process: https://www.ptc.com/support/-/media/support/refdocs/Windchill_PDMLink/11,-d-,1/WCRehostUtility.pdf?sc_lang=en&source=search
FT_11575036
(To:Milan)
Hope that helps.
BenLoosli
(To:Milan)
I have done this at Windchill 7. The server we had was so underpowered we had to reboot it twice a day to keep the method servers from choking. Put in a new 8 core processor system with 16GB of memory and copied the Windchill application over and reconnected it to the existing DB server. Rehost guide was worse than it is now back then but I got through it. Many of the changes in the Rehost guide were because of my complaints and working with the documentation group to make the changes.
Catalina
Moderator
(To:Milan)
Hi @Milan,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
