Renaming Instances in Family Tables
otcunanan
I renamed the instances of a family table inside Creo instead of File>Rename in Windchill as I now understand I should have. Now the generic is tied to the new parts that were created.
Currently, my generic is at 1.6, if I go into the history tab and go to the details of the 1.5 iteration, I see that the generic is tied to the original instances that existed before renaming the instances. I plan to take the 1.5 iteration, check it back in to overwrite the 1.6 iteration and create the 1.7 iteration where the instances are back to their original names.
However, I still need to rename the instances, this time through Windchill of course.
See below for clarification. If I overwrite Generic 1.6 with Generic 1.5, will I be able to rename "old_inst1" and change it to "new_inst1"?
new_inst1 represent a nomenclature that I need to keep.
What I have now:
Generic (1.6)
new_inst1
new_inst2
What I will use to overwrite:
Generic (1.5)
old_inst1
old_inst2
Using Creo3m110; Windchill 10.2
Needed Windchill Admin to temporarily allow checkout of Non-Latest iteration in order to overwrite latest iteration.
From the PTC Article:CS22588
Preference Manager > Create and Edit > Allow checkout of non-latest iterations supported for CAD Documents and is not valid for WTDocuments or WTParts.
Had to rename New_inst1 to DNU_New_inst1, in order to free up the name for use.
