I've recently been given the order to look into renaming the existing Organizations we have in our Windchill PDMLink system. PTC has a document (CS52976) that makes it seem relatively straight forward.
Does anyone have experience doing this? And what sort of pitfalls should I be on the lookout for?
Thanks in advance.
I did this in a Dev environment a while back, and I had no issues. Basically, we wanted to change the organization name from a division to that of the entire company. It went off without a hitch.
Micah
It was one of two organizations. I cannot remember if it was the default organization, and it was just a hypothetical. We restarted and verified some basic functionality, and then ended there.
You might also want to view CS39159 - although that is about a skimpy as a CS can get.
